50/30/20 AMP RV Power Installed! May 01, 2020, 12:39:49 pm After a short 2 day process, power for my RV has been installed on the family farm. I think things went so quickly because of the shut-down and some trades not working as much as they normally would at this time of year (both the electrician and the electric company guys). We decided to connect the 50, 30 and 20 AMP so that 2 RVs can have service at the same time if needed (unlikely though) or if I upgrade in the future (also unlikely).The first step was for the electrician to build a 15-foot tall conduit pole for the wiring and the 100 amp power and meter boxes. That took about 2 hours yesterday.This morning the workers from the local electric company (Blue Bonnet) arrived to attach the conduit pole to the existing power pole and connect the power. In this case, the electrician did not give them enough tails to connect to the "bucket" but they made it work. They needed 5 to 7 feet of tails. The actual work took a bit over an hour because the bucket made the work go so much more quickly and safely than a ladder.The electrician was on site while the Blue Bonnet guys were working and started prepping the GE 50/30/20 AMP box I purchased from Home Depot. Once they left he spent about 90 mins installing my box. It took him a little longer because the pole is on the cow side of the fence and he had to keep climbing over or going around the barbed wire fence (a literal pain).Once the install was completed, I brought out my Surge Guard 30 AMP surge protector to check the connection. Not good. We kept getting a flashing caution red light. I showed the electrician how the surge protector was supposed to react/work when the connection is good by connecting the surge protector to a dog bone and then to the regular 110v outlet from the garage. He then figured that he needed to make a change to the ground and neutral wires (I forgot exactly what he said he did). When he made that change, and we re-connected the surge protector, it worked as normal. We also tested the 50 AMP service using an adapter and the surge protector and it worked fine as well.The price is just under $1000 for everything (including the $157 + tax box I bought). I don't have the exact figure yet.I am about 80 feet from the power and I could move closer to it, but I like the spot I'm in better. :-)Yay! Nighttime AC in humid Texas without the generator! 6 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #1 – May 01, 2020, 12:43:36 pm I hit "post" too soon. 3 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #3 – May 01, 2020, 02:11:54 pm Nice!. Now the family farm is ready for a caravan or for your RV friends to visit in warm weather.Larry 3 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #4 – May 01, 2020, 02:17:01 pm "Now the family farm is ready for a caravan or for your RV friends to visit in warm weather."----Hey, I'm good with staying on the 'cow side'! 2 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #5 – May 01, 2020, 05:24:13 pm Quote from: debinvenice - May 01, 2020, 12:39:49 pmAfter a short 2 day process, power for my RV has been installed on the family farm. I think things went so quickly because of the shut-down and some trades not working as much as they normally would at this time of year (both the electrician and the electric company guys). We decided to connect the 50, 30 and 20 AMP so that 2 RVs can have service at the same time if needed (unlikely though) or if I upgrade in the future (also unlikely).The first step was for the electrician to build a 15-foot tall conduit pole for the wiring and the 100 amp power and meter boxes. That took about 2 hours yesterday.This morning the workers from the local electric company (Blue Bonnet) arrived to attach the conduit pole to the existing power pole and connect the power. In this case, the electrician did not give them enough tails to connect to the "bucket" but they made it work. They needed 5 to 7 feet of tails. The actual work took a bit over an hour because the bucket made the work go so much more quickly and safely than a ladder.The electrician was on site while the Blue Bonnet guys were working and started prepping the GE 50/30/20 AMP box I purchased from Home Depot. Once they left he spent about 90 mins installing my box. It took him a little longer because the pole is on the cow side of the fence and he had to keep climbing over or going around the barbed wire fence (a literal pain).Once the install was completed, I brought out my Surge Guard 30 AMP surge protector to check the connection. Not good. We kept getting a flashing caution red light. I showed the electrician how the surge protector was supposed to react/work when the connection is good by connecting the surge protector to a dog bone and then to the regular 110v outlet from the garage. He then figured that he needed to make a change to the ground and neutral wires (I forgot exactly what he said he did). When he made that change, and we re-connected the surge protector, it worked as normal. We also tested the 50 AMP service using an adapter and the surge protector and it worked fine as well.The price is just under $1000 for everything (including the $157 + tax box I bought). I don't have the exact figure yet.I am about 80 feet from the power and I could move closer to it, but I like the spot I'm in better. :-)Yay! Nighttime AC in humid Texas without the generator!Thanks for the photos and info, Deb. Since you are parked in a pasture, if you will be there for a while, you might consider putting a couple of bags of moth balls under your hood for rodent protection, and then put a note on your speedometer to remind you they are there. I just did this an hour ago at my storage facility. Enoz Old Fashioned Moth Balls, 16 Oz, 2 Single Use 8 Oz Packets - Walmart.com...Chris 3 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #6 – May 01, 2020, 06:00:47 pm Quote from: Chris Horst - May 01, 2020, 05:24:13 pmThanks for the photos and info, Deb. Since you are parked in a pasture, if you will be there for a while, you might consider putting a couple of bags of moth balls under your hood for rodent protection, and then put a note on your speedometer to remind you they are there. I just did this an hour ago at my storage facility. Enoz Old Fashioned Moth Balls, 16 Oz, 2 Single Use 8 Oz Packets - Walmart.com...ChrisThanks for the idea, Chris. I'll pick some up the next time I'm in town. :-)I have some twinkle LEDs that I use from time to time and now that I have regular power I may try those under the hood as well. I do move once a week to go to a nearby state park to dump my tanks (they are open for day use in Texas). 1 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #7 – May 01, 2020, 07:43:39 pm Quote from: debinvenice - May 01, 2020, 06:00:47 pmThanks for the idea, Chris. I'll pick some up the next time I'm in town. :-)I have some twinkle LEDs that I use from time to time and now that I have regular power I may try those under the hood as well. I do move once a week to go to a nearby state park to dump my tanks (they are open for day use in Texas).Of course there are lots of opinions on the effectiveness of moth balls. I've had no mice problems using them, but I just might not have mice. Anyway, it's a cheap fix.Chris 2 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #8 – May 02, 2020, 09:29:22 am Two thoughts ...1. You were very lucky you had a 15k pole near your 'home'. Someone in the past must of paid a 'pretty' penny getting it there.2. Congratulations on double checking the hookup. It's a very common mistake to reverse the neutral and ground. glen 1 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #9 – May 02, 2020, 12:06:46 pm Deb,Congratulations and GREAT JOB! To get those guys making all you connections for $1000 is a steal and money well spent. It would have cost a small fortune in California!LED rope lights for rodent control. Use a photocell timer to turn on at dusk and off at dawn.Harold 1 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #10 – May 02, 2020, 12:39:02 pm Quote from: colddog - May 02, 2020, 09:29:22 amCongratulations on double-checking the hookup. It's a very common mistake to reverse the neutral and ground. It's not uncommon to find hookups improperly wired, our EMS-HW30C surge protector has found several through the years.Usually, it's the neutral and ground wires that are reversed or one of them is missingThe beauty of a good surge protector is it will not connect to dangerous wiring.Larry 2 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #11 – May 02, 2020, 04:00:21 pm Quote from: colddog - May 02, 2020, 09:29:22 amTwo thoughts ...1. You were very lucky you had a 15k pole near your 'home'. Someone in the past must of paid a 'pretty' penny getting it there.2. Congratulations on double checking the hookup. It's a very common mistake to reverse the neutral and ground. glenThe power pole was there because once upon a time, along with the cows, my mother and stepfather were raising Emus. There was a building used for hatching the eggs near where I'm parked. The Emu business was a bust but luckily for me, the power pole was left behind and ready for my use! :-) 2 Likes
Re: 50/30/20 AMP RV Power Installed! Reply #12 – May 02, 2020, 06:02:46 pm "...once upon a time, along with the cows, my mother and stepfather were raising Emus."---OK, you might know that I had to look up a few of the ins and outs of 'emu-culture'. Cows - 1, Emus - 0. 1 Likes
