Add option "None" to Lazy Daze Models for Profile June 11, 2018, 10:12:38 am It would be useful if members could set their Lazy Daze model to None on their profile. This would help with the member map, and looking for people near you with a certain model. I think the default model is Twin King right now.Wade
Re: Add option "None" to Lazy Daze Models for Profile Reply #1 – June 11, 2018, 01:53:50 pm Quote from: Matisse - June 11, 2018, 10:12:38 amIt would be useful if members could set their Lazy Daze model to None on their profile. This would help with the member map, and looking for people near you with a certain model. I think the default model is Twin King right now.WadeWade, there is no "none" setting. If a member doesn't have an LD or is searching for one, s/he often indicates so in the profile, just like you did. Otherwise, I always try to put the members' year and model LD in the profile in order to minimize future questions. Not everyone elects to use the member map. Assuming you are looking for someone near you to look at their LD, the best way to accomplish that is to post a message accordingly.Chris 1 Likes
Re: Add option "None" to Lazy Daze Models for Profile Reply #2 – June 11, 2018, 02:35:39 pm Quote from: Matisse - June 11, 2018, 10:12:38 amIt would be useful if members could set their Lazy Daze model to None on their profile. This would help with the member map, and looking for people near you with a certain model. I think the default model is Twin King right now.Hello Wade and welcome to the LD Owners' Forum. Looking forward to hearing from you in the future and hope you find a home in this Internet Forum. 1 Likes
Re: Add option "None" to Lazy Daze Models for Profile Reply #3 – June 12, 2018, 03:34:41 pm Quote from: Chris Horst - June 11, 2018, 01:53:50 pmWade, there is no "none" setting. If a member doesn't have an LD or is searching for one, s/he often indicates so in the profile, just like you did. Otherwise, I always try to put the members' year and model LD in the profile in order to minimize future questions. Not everyone elects to use the member map. Assuming you are looking for someone near you to look at their LD, the best way to accomplish that is to post a message accordingly.ChrisYes, I am saying you should add the None option. I know it is possible because the Foretravel owners forum, which seems to run on the same software as this forum, has the ability. Good idea about the showing request post.Thanks,Wade
Re: Add option "None" to Lazy Daze Models for Profile Reply #4 – June 13, 2018, 09:59:11 am Quote from: Matisse - June 12, 2018, 03:34:41 pmYes, I am saying you should add the None option. I know it is possible because the Foretravel owners forum, which seems to run on the same software as this forum, has the ability. Good idea about the showing request post.Thanks,WadeAsk and ye shall receive. "None" is an option now.Chris 3 Likes
