Removing the Hot Water Heater Pressure Relief Valve December 21, 2017, 11:27:19 am I did this years ago. It was easy. Not so now.There is probably a special wrench designed for the purpose?If I remove the shroud to the left of the valve I might get a small pipe wrench on it.Or is there a simple way.Just want to soak it in vinegar, it's been in there for several years,
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #1 – December 21, 2017, 11:35:11 am Don ... mine was a bit tight when I removed it last year. I just used a bigger wrench and it broke loose. If it's really stuck, I might consider a shot of penetrating oil. And I didn't need to remove the shroud. The PRVs are rather inexpensive so you might consider a new one.
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #2 – December 21, 2017, 12:18:17 pm Is the valve directly screwed into the hot water tank?
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #3 – December 21, 2017, 01:09:42 pm Don, I agree with Ed & Margee. If you're going to the trouble to remove the valve from the water heater, replacing it is a wise decision IMHO. 1 Likes
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #4 – December 21, 2017, 01:27:11 pm Camco sells a tool for removing and replacing the P&T valve:Camco P&T Valve Removal Tool on AmazonFor a one-time use, it's pricey. Better to borrow one from your friend who has every tool- you have afriend like that, yes?Mark As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #5 – December 21, 2017, 04:05:35 pm Mark, that is what my service guy used when he did mine a year ago. It was crudded up and had a slow leak. He used a 24" breaker bar with a 2 foot pipe extension to break it free.Ken F in NM
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #6 – December 21, 2017, 04:11:28 pm Maybe shop around? Seems cheaper here:Camco 10552 Universal Temperature and Pressure Valve Remover
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #7 – December 21, 2017, 04:25:44 pm Quote from: Kenneth Fears - December 21, 2017, 04:05:35 pmMark, that is what my service guy used when he did mine a year ago. It was crudded up and had a slow leak. He used a 24" breaker bar with a 2 foot pipe extension to break it free.Ken F in NMKen-Amazing what a little aluminum/brass interaction can do. I used the tool, but a regular wrench. I suspect it came out easier because the water heater was only a few years old.I'd offer to give Don the Camco tool I bought (as I shouldn't need it for a while), but it's at home and I'm not.Mark
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #8 – December 22, 2017, 02:11:28 am Not having the dedicated tool, I use a 12' crescent wrench opened up and slipped over the end of the relief, so the wrench is sticking outward. A extra long screwdriver is inserted through the hole in the crescent wrench's handle. It's used with a breaker bar to loosen the valve..Crescent 12 in. Adjustable Wrench-AC212VS - The Home DepotLarry
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #9 – December 22, 2017, 10:31:45 am Quote from: Larry W - December 22, 2017, 02:11:28 amNot having the dedicated tool, I use a 12' crescent wrench opened up and slipped over the end of the relief, so the wrench is sticking outward. A extra long screwdriver is inserted through the hole in the crescent wrench's handle. It's used with a breaker bar to loosen the valve..Crescent 12 in. Adjustable Wrench-AC212VS - The Home DepotLarryHaving trouble seeing this. Is the wrench handle in line with the valve? 90 degrees to the rig?Picture?Merry Christmas
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #10 – December 22, 2017, 10:32:34 am Quote from: JCT - December 21, 2017, 04:11:28 pmMaybe shop around? Seems cheaper here:Camco 10552 Universal Temperature and Pressure Valve RemoverWith shipping same as Amazon free shipping
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #11 – December 23, 2017, 12:48:41 pm does the atwood take the 3/4"(90028) or the 1/2"(91604) valve?
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #12 – December 23, 2017, 01:31:09 pm Quote from: mcnugget - December 23, 2017, 12:48:41 pmdoes the atwood take the 3/4"(90028) or the 1/2"(91604) valve?I'm looking at my receipt and it looks like ours was a 3/4" valve, model number is 10473.Hope this helps. 1 Likes
Re: Removing the Hot Water Heater Pressure Relief Valve Reply #13 – December 23, 2017, 02:06:52 pm Quote from: Ed & Margee - December 23, 2017, 01:31:09 pmI'm looking at my receipt and it looks like ours was a 3/4" valve, model number is 10473.Hope this helps.yep, that's the camco # for 3/4". thanksfyi all 3 of these part numbers are 150psi valves. Atwood also has a 75psi, 3/4" RV that is p/n 92647...
