Topic: Refrigerator II (Read 616 times) previous topic - next topic
Re: Refrigerator II
"The foam extinguishers are great for RV use, they do not cause much damaged, if used."
Larry or other wise and experienced Lazydazer, the subject of fire extinguishers makes me wonder this;
What is a good extinguisher that will fit in the fire extinguisher cubby hole? And where else have you mounted extinguishers where they are accessible and yet not in the way?
Thanks for any help in this area. We still have the original extinguisher that came with our rig in 2003. We also have a small one in the compartment below the fridge.
Re: Refrigerator II
Exits in the RB? Although the shower window opens and could be used, I discount it due to its size, but yes it is a possibility.
Hmmm...does the RB Galley window open? I've never checked, but even if it does I doubt it would make a useful emergency exit.
Then there are:
Drivers side dinette window. (1)
Drivers side sofa window.      (1)
Drivers Cab door.                    (1)
Passenger Cab door.              (1)
Passenger Side sofa window (1)
Coach Door.                            (1)
Shower Window (awkward).  (1)
Total Recalculated w/shower=7
The 2015 RB has no Escape Hatch.
Re: Refrigerator II
Then there are:
Coach Door.                            (1)
Thanks, Kent. The bathroom window does not open, correct?
Re: Refrigerator II
Steve,
Unless you have agitated (shaken up) the LD original Dry Chem Extinguisher periodically, it is most likely useless as the chemicals have probably settled to its sides and solidified (that's my understanding).
Where are my extinguishers? I have Five 16 oz Foam Extinguishers that I purchased from Walmart for under $25.
They are placed strategically around the rig. Mine is a RB so placement may vary per model:
One above the Passenger Side Sofa in the cupboard- front left side. Easy to see and grab.
One above the stove in the cupboard right side next to a Large Fresh Box of Baking Soda (another fire retardant).
Two in the Bath Room Cabinet below the sink. Front left side in front of everything else. Easily spotted.
One Outside Passenger Side Top Bay. Right side in plain sight.
HALATRON EXTINGUISHERS (2):
One Mounted on its own bracket bolted on the Bulk Head behind the TV in the Over Cab Sleeper. Easy to get and kinda out of sight. But it's there.
One in the RB Closet mounted flat on its own removable wooden plank. The extinguisher bracket is bolted to the plank. The plank is Velcroed to the lower shelf on the left. It's placement here is to provide for its use when caught in the rear of the coach. It can help knock down flames when trapped by fire and you are heading toward the exit.
As always, I hope I never have to use any of them. When I told Vince about my Extinguisher Set-Up, he was a bit taken aback thinking I had gone to extremes. I explained that it was all precautionary. After that, he saw my point.
Hope this answers your question. Is it over the top? I don't think so. My late Father was a Firefighter for Los Angeles County and I think he would approve.
Re: Refrigerator II
Greg,
Yes the RB shower window does open, however the window itself is small and the opened space is only 1/2 its width.
Might be good for passing a small pet through or perhaps an infant.
Re: Refrigerator II
Greg,
That's good to know. So many of the SOB's windows don't open at all.
Re: Refrigerator II
[ Quote] Unless you have agitated (shaken up) the LD original Dry Chem Extinguisher periodically, it is most likely useless as the chemicals have probably settled to its sides and solidified
To properly maintain a dry chemical extinguisher, periodicly pick it and turn it upside down. Smack the side with something solid. When the power is tightly packed, you will feel the powder fall.
Repeat a couple times before replacing the extinguisher in its cradle.
Also check the pressure gauge to ensure it is still pressurized .
Re: Refrigerator II
"Where are my extinguishers? I have Five 16 oz Foam Extinguishers that I purchased for under $25"
Thank you Kent.
Can you tell me the brand and model of the foam extinguishers you bought?
I do appreciate the detailed answer and the info about shaking up the old extinguisher. I had never heard that before; all I have done is look at the guage.
Re: Refrigerator II
As Larry mentioned, smack it with something hard. A hard rubber mallet works nicely; just smack several times on and near the bottom where the chemical settles.
Re: Refrigerator II
Steve,
I purchased 6 "Fire Gone" foam extinguishers on Walmart's website and picked them up at a local store. I kept one in the S&B's near the stove.
 The current ad states the price at almost $11 each. I purchased mine on sale.
Here is a pic of the current listing on Walmart.com
Re: Refrigerator II
Joan,
Always something new on the horizon. I located a 20oz Cold Fire Extinguisher on Amazon for a fair price. eBay has a 13 oz can for under $20.
Another tool in the arsenal for fire preparedness. Should fit nicely about midship in the coach.
Re: Refrigerator II now fire extinguishers too
Kent, thanks for sharing your fire extinguisher suggestions. I will be using them as I update our rig this spring.
Steve K.
