Topic: Biggest LD improvement yet: Valterra Reverse RV Flush Valve (Read 478 times) previous topic - next topic
Happy Holidays everyone,
I thought I'd share our experience with what we think is the best improvement we've made to our 2016 TK yet. It's actually a +/- $35 accessory for dumping the grey and black tanks by Valterra called the Reverse RV Flush Valve (available on Amazon: Amazon.com: Valterra F02-4350 Reverse RV Flush Valve: Automotive . It makes the job of flushing the tanks so fast and easy, we almost can't believe it.
We were looking for an option to the way the LD manual tells you to flush the tank (only directions to flush the black tank are provided). LD says to drag a garden hose into the bathroom and fill the black tank through the toilet. We used this technique and didn't like the water that inevitably drips on the floor, or having to stand there holding the hose. But, worse was that opening and closing the toilet and holding your foot on the pedal; and/or leaving the bowl valve open as you fill the black tank from above, allows the stench to enter the RV.  And, also annoying was how long it takes to fill the tank this way.
Reading up on alternatives and watching lots of youtubes, it was clear that a better way would be to do the whole job from outside. I considered adding a flush valve to the black tank but the kit was a little expensive for what it was and I couldn't see any easy way to access the black tank with an electric drill to install the flush valve. I didn't really want to mess with Lazy Day's careful construction either.
Since the Valterra Flush King simply connects to the dump pipe on the Lazy Daze, I decided to forget about trying to modify the black tank and just go with the Flush King. It twist connects the same way the hose does so it goes on easy and fast. Then you connect a water hose to the inlet on the Flush King and you're ready to dump and flush and repeat as much as you want. And the only reason to enter the Lazy Daze during the process is to press the button on the control panel to determine when the black tank is full (it also works for the grey tank).
Using the Flush King, we were able to fill the black tank enough for the red light to glow on the control panel is a mere 3 minutes (we haven't tried flushing the grey tank yet). Not a drop of water was spilled inside the LD and no smells, either. Since it fills so fast, as an experiment, I filled and emptied the tank 3 times and even on the third time there was some debris remaining. Which just makes us even happier we have a much easier way to flush the tanks now.
Hope this is helpful,
Jim and Deb
Santa Cruz, California
2016 24' TK
Re: Biggest LD improvement yet: Valterra Reverse RV Flush Valve
Glad you're happy with what apparently works for you.
One thought... since I'm not familiar with your plumbing I wondered if there are any twists or turns or elbows involved in the process of flushing? In other words, are you sure all of the flush water is reaching the back of the tank? I recall that Andy Baird once used a camera to inspect the insides of his tank.  ::)
Flush Kings work great on tanks where the outlet enters directly into the holding  tanks.
On holding tanks drains that have a long run, from the tank to the outlet, they don't have much mechanical flushing force.
Here is a photo of our LD's holding tank plumbing. The small pipe is from the gray water tank.
Drain pipes | Shows location of second set of drain valves. | lw5315us | Flickr
The small 1-1/2" pipe, combined with long run and two turns, slows the flushing action to the point where it is ineffective.
In this situation, an in-tank flusher works much better.
Holding tank flusher | Flickr
Camco in tank flusher.
Amazon.com: Camco 40123 Quickie Flush with Back Flow Preventer: Automotive
We use the same  Flush King device on our TK and it does a great job.
Mostly it takes me filling the tank to the top twice until I get an empty inidication that means the crud that sometimes hangs onto the sensors is gone.
On the second time , the water coming out is very clear.
Ed
I use a Flush King on our mid-bath and our new coach. My main interest is in filling the tanks quickly, which the Flush King does, and then dump. Three cycles is usually enough to ensure a clear discharge. It took more cycles than that the first time with the new coach, which happens to have a tank rinse system. I'm not sure the prior owners used it. This coach's tank rinse system is slow, and its "impingement" minimal, so I'll probably continue to back-flush in addition to using the rinse system.
The Flush King filled the LD's tanks in about four minutes. It helped to have installed a SeeLevel tank level reading system, as you can set it for continuous readout and watch the numbers climb from outside the coach door, in time to scoot around the coach and shut off the water before the tanks are full.
If someone is tempted to buy the less-expensive Camco look-alike, beware. As made it has a small orifice, and according to reports a low gallons-per-minute water input rate. I bought one a couple months ago to try, because Valterra doesn't make the Flush King with a straight clear section. I drilled out the Camco's orifice to the largest I felt I could, about one-quarter inch. We'll see during the next trip if that brings the Camco into the same league as the Flush King.
Mark H.
Former owner, 1997-8 mid-bath
I use a similar device on my black tank (mid bath).  It jets directly into the tank, but it only gets to the lower end of the tank.  My routine is to flush for several dumps this way, then about every 4th or 5th dump, I flush this way, then I switch the water hose to a flush wand and do the tank from inside.  The water had been running clear with the flush device, but a lot of crud comes out when I then do the flush wand.  So, do not count on it to get everything.
Whatever works for you. I went the cheap route. $30 less than a Flush King. Get a dump cap that has a hose fitting on it. It will be a male fitting. Get two female hose repair fittings and put them on a short length of hose or clear tubing. One end screws to the dump cap the other to your OK to fowl hose connected to a high pressure outlet. Be very sure that the dump valve is open before you turn on the water or your dump cap will pop off and need replacing.
I have no problem filling from the inside. I just put the hose in the opening and lay down and read while it fills. No order because the tank is empty when I fill it from the top or through the dump valve.
I leave all tanks full when stored. No chance of freezing here. I put Pinesol or the like the gray and black tanks and Clorox in the fresh water. Everything is fresh in the spring.
Flushing, flushing, two or three time in succession!
Whenever I hear stories like that I cringe. Here in Kalifornika, where we are in the midst of sever drought conditions my water bill would go into orbit if I did that!   :'(
Sounds like the previous owner installed but didn't use the in-tank flusher. If not used, the nozzle will fill with dried debris and plug up. I installed our LD's flushers almost 14 years ago and they still work fine.
In rigs, like the T/K, where the dump valve is at the end of the tank, the Flush Kings works great. Out 1983 22' FL had the same dump valve arrangement and a Flush King (called at Hydra Flush back then) was used for the eight years we owned it.
Unfortunately, the Flush King would not adequately clean the gray water tank on our 2003 FL, so the in-tank flushers were installed.
Not needing the Flush King anymore, it was recycled into a DIY macerator, this was before the pre-built macerator kits were available.
Macerator pump | Flickr
I am totally with you on this!  I can't picture wasting 40-50 gallons of water.
2014 TK
The Super Flea
I read comments about this issue before buying the Flush King, Lazy Bones, and was concerned, but now that I own it and have seen how it works, it doesn't make any difference how many twists and turns are in the plumbing. The only important thing is that there aren't any gates or seals or one-way valves. Because the water flushes by filling up the tank, not shooting into the tank like the different type of flushers. As long as you shut the gate so that the water can't escape down the sewer hose to the dump drain outside, the only option the water has is to gradually fill and fill until it fills all the pipes to the entrance to the black tank where it starts to fill the black tank. When the black tank is completely full - or whenever you want to stop filling the black tank, it's when you open the gate valve that the flushing begins. I guess filling gets everything wet but it's not like the spray from the hose is going to reach the black tank. That's a different type of flushing device and the two aren't the same at all.
Hope that helps explains how the Flush King works and how foolproof it is. I was confused by all the confusion out there between the two types of systems so I hope I explained it well enough.
Best wishes,
"Hope that helps explains how the Flush King works and how foolproof it is."
Except if you forget and overfill, in which case the black tank's contents start coming up out of your toilet!
Your word picture helped me visualize the process quite well. So the flushing action begins with the opening of the gate valve once you have determined that the tank is as full as needed... I get that.
Now I'll interject my procedure. Even prior to the acquisition of my 2004 LD I had a 30' HR TT which I owned for ten years (1994-2004). On both RVs I have always used Eco-Save toilet chemical. I NEVER open the BW tank valve unless I intend to dump, regardless of the fluid level inside. I dump the BW first, followed by the GW to rinse the hose. Once the dump process is complete I recharge the BW tank with the Eco-Save and one bowl full of fresh water. And that's how she rides until the next dump cycle. I have never, in twenty-two (22) years, felt the need to 'flush' my BW tank. And so it goes!  :)
Just filling and draining the tanks does mot necessarily knock things off the side of the tank, as there is no blasting action,  especially in  tanks with  constricted outlets. The 1-1/2" drain pipe does not drain quickly, the low flow havng little debris carrying power.
In-tank flushers are actual spray nozzles that scour the inside of the tank.
I have compared the Flush King to the in-tank flushers and the flushers get more 'stuff' out.
The other advantage with flushers is that much less water is needed to clean the tank.
We too live in an area with water use restrictions.
Thanks, Steve,
The reason we had the idea that it was important to flush the black tank is because on our previous Class B RV, a Roadtrek Agile SS, the control panel constantly showed a half full tank even though we kept trying to empty it more. We asked other RVers who told us that we should ignore the sensors, that they would always be wrong and that the tank was empty, just the sensors had debris on them.
Now, with the Lazy Daze, the sensors have always shown empty once we dump the tanks. But having had the experience with the Roadtrek we thought we needed to flush out the tanks just to make sure the sensors don't get messed up like the Roadtrek's. From your experience, it sure sounds like we could be wasting our time and water, too. Thanks for sharing!
"...just to make sure the sensors don't get messed up like the Roadtrek's."
Those 'sensors', mounted as they are on the inside of the tank, are not your friends! They are always exposed to contamination from the tank contents and will eventually give you false readings. I long ago abandoned all use of the LD Monitor Panel in favor of the SeeLevel System.
709-P3 SeeLeveL IIâ„¢ Tank Monitor System - Garnet Instruments
The SeeLevel sensors are mounted on the outside of the tanks and therefore cannot be contaminated. Plus they are extremely accurate, providing levels as a percentage of full. Many Lazy Daze owners have had them installed.  :)
My use of the Eco-Save chemical is what keeps my tanks clean. It is an enzyme based compound, unlike the formaldehyde stuff (which is a preservative) and those little critters just gobble up all that yummy stuff inside the tank, leaving behind nothing but a thin brown slurry.  8)
Sewage, toilets, black tanks.  All topics that we really don't want to deal with often.  It is even worse on a boat when offshore.  The head is the worse thing to have fail offshore and if it does, it MUST be fixed or everyone becomes very quickly unhappy, uncomfortable, and embarrassed.  Then yours truly ends up in the hot engine compartment taking apart a very messy, nasty system with pumps, vacuum valves, and multiple places for blockage.  Everything is moving and the motion combined with the aroma adds to discomfort while working.  Alcohol does not help.
The solution is that NOTHING goes into the head that hasn't run through the users body first. That means all paper products go into a zip lock bag and then into the trash and never into the head.  Since we started using this policy in our RV's as well, we rarely ever have a failed sensor and our gate valves last longer.  I still flush the black tank periodically, but not every dump and the sensors haven't failed for years.
If children or clueless guests are aboard, get out the plumbing tools...
Harold
