Topic: LD has been largely idle for 8 years -- suggestions please (Read 918 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Re: LD has been largely idle for 8 years -- suggestions please
Steve, I tried to search for links to the repair database too, had no luck.
I hate to add to requests for stickies, but maybe we need one?
I have a couple of shop experiences to add too.
'92 Mid Bath
Steve, see my post regarding "Maintenance/Repair Facilities" in the Lazy Daze General Info & Discussions forum.
Thanks Chris,
That worked -- I was able to get to the old data base, and it was properly formatted on my laptop.  I saw only two entries for NH, and neither were in close enough for me to travel to, but at least it is good to know I'm not missing something noteworthy.
A question -- do folks still see value in this data base?  Maybe "the power of the internet" as supplanted the need for such a data base, I don't know.
Not knowing the internals of the new forum, is it possible to set up a sortable table, that can perhaps can be tied to a map if that is of any use to someone?  I dunno, just an idea if the moderators see value of trying to re-build such a table over here.  I would have to assume Yahoo will be gone at some point -- so thanks again to you Chris, and others, who did all the heavy lifting to get this LD forum moved onto a modern platform.
In any case, I appreciate the pointer to the old repair and maintenance data base.
S-
Thanks Chris,
S-
Steve, I have put this question of some sort of maintenance/repair facility data base to our forum administrator, Steve Cook. I should have an answer soon.
"...do folks still see value in this data base? "
I don't see much value except maybe as a starting point to look for a service location, primarily because most of the data is old (if the entry was dated at all) , many of the recommendations did not include the type of work or specific job that was done, or the review mentioned (positively or otherwise) only an experience with a particular tech or service person who may be long gone. IOW, the information in the review may be irrelevant to the current status of the shop.
Circumstances can change quickly; shops change ownership (for good or bad!) or go out of business altogether, personnel come and go (many tire shops have high employee turnover), and the types of services offered (and to what kinds of vehicles they're offered) may not be at all the same as when the original review was written.
I do think that a service and maintenance category on this board would be useful to supplement information available online;  the reviews and testimonials found on the web are not necessarily up-to-date or accurate, either, but as many sources of "guidance" as possible are usually good to check consistency of opinion and experience. (I did send Chris suggestions on "information inclusion" points for the category a while back.  ;) )
Joan
Steve, don't know if you are familiar with this web database. I have used it a couple of times over the years and been satisfied.
http://www.rvservicereviews.com/Index.asp
Jim, I did not know about that, and it looks very helpful.  I found a couple of facilities within 30 miles of me that are probably worth considering.  So thanks for this lead.  If I run into troubles or limitations with LDN, I now have some alternatives ;-)
Joan, I agree with your instincts.  Chris, I think in the grand scheme of things, perhaps we are too small a community to gather enough data points, reviews, and for them to be relatively current.  The site the Jim pointed me to would seem like a good starting point for our LD community as well.
Thanks again for everyone's assistance and willingness to assist/make recommendations.
S-
Were I stranded in a place where I knew no one to ask for a referral, this database might be of use.  Obviously I can't speak for all of the entries, but before having read Joan's post, I had already gone to the database to check out my own area to see who was mentioned and what the comments were.
Our main repairman is prominently mentioned, with one bad review, amongst a flurry of praise.  This repairman has been doing our RV work since the late 80's, and we have been more than pleased - as you might imagine with that kind of longevity of experience.  The one bad review is so totally off the wall, and so unlike the owner, that I cannot possibly imagine what transpired.
Of course everything Joan says is totally true, and I have only the one data point to illustrate.  That is why our merry band is so important in all things Lazy Daze.  Should someone need repair work done in my area, I could easily point them to the database with personal experience and recommendations.
I haven't tried this tack, but were I stranded and searching out a place to assist with no personal recommendations to guide me, I might just do a global Google search for the name of the shop(s) suggested by the database to see if there is anything startling - either good or bad.
If one has a road service, there might be merit in asking them for recommendations, but, of course, you have no idea how they select their recommendees.  AAA also provides this recommendation service.
Virtual hugs,
Judie
Joan
Hi folks - OP here,
Just an update to say that we found what we believe (hope) to be a competent mechanic to work on our 26.5' Mid-Bath LD.  Turns out the wheelbase was the maximum size that would fit on their lift.  (FYI - the shop is called LDN Auto Repair, located in Milford, NH.)
Anyways, special thanks to those of you that provided suggestions on what we might need to do after sitting unused for 8 years.  We managed to get it running smoothly and have taken a couple of short "shake-down" cruises, and fired up most of the house equipment.  Impressed the generator fired up (after blowing out what looked like a mouse nest from its exhaust).  Levelers worked great (and dry-siliconed the rams).  The issue causing the fast idle turned out to be mouse next somewhere in the air filter housing.  All the fluids have been flushed and replaced.  Serpentine belt replaced.  Hoses and vacuum lines checked for damage or dry rot.  Etc.
So again, thanks for the assistance.  We plan on taking this on a long winter sojourn out west, probably starting in January of 2017.  So we feel pretty good that we won't be broken down on the side of the road (fingers crossed).  I will give a shout out to Progressive Insurance.  My fast idle problem eventually turning into a would not maintain any idle, and would stall.  So I had to get the RV towed to LDN Auto Repair about 5 miles away.  They covered the full cost (not cheap, needing a big wrecker) with no hassle.
Finally, one remaining question for the group:  we have had our water system winterized with RV antifreeze for this entire 8-year period.  Does any one have any special thoughts on how to clear that out and get the water system to not have any leftover "taste".  I would welcome pointers to posts or files that describe (a) the proper way to flush the water systems after using antifreeze, and (b) instructions/tips for using compressed air for winterizing the the future, as that is my goal next time.
Thanks again for everyones help.  Hopefully be seeing some of you on the road this winter.
S-
Hi folks - OP here,
S-
Steve, glad you are up and running. I added the repair shop you mention to the list of recommended facilities (Lazy Daze Gen. Info & Discussions Forum) If for any reason you change your opinion of service at LDN, let me know so I can correct the posting.
If you Google "how to flush an rv water system of antifreeze" you will find a lot of discussion on your question.
Thanks for posting the "sitting rig" update. Can't help with winterizing, but many on the board do this, so I'm sure you'll get responses. Happy Trails!
Joan
Thanks Chris — you may want to make a note about the LDN listing.
If someone calls and tells LDN Auto Repair they have an RV, they will say “we don’t work on RVs”.
So perhaps add a comment that if someone needs that facility, give Steve Crisp a call at 603-732-3668 and I can try to ease them into it.
Or note that they should say it is the same size wheel base as Steve Crisp's RV (or less if a 23.5’), and therefore it shouldn’t be an issue.
Whatever you wish to do — I just don’t want someone to call and them get turned away without knowing the “secret password”.
Thanks again,
S-
Thanks again,
S-
Thanks, Steve. I added a footnote to the LDN listing.
