Demineralizing hotwater tank on 96 Tk May 11, 2016, 03:12:47 pm Yahoo Message Number: 160438My hot water Kettle with visible heating element is my barometer for the heating coils in my hot water tank. After staying in Texas 3 months, I realized that the mineral buildup in my kettle was probably matched in the hotwater tank. I called Atwood and was given a water to vinegar ratio. We realized we can empty the tank, but not sure how to get the vinegar and water into the hot water tank. The geek video uses a switch that we don't have on our 96. The LD resource files don't address this issue that I can see. We know to empty the tank, and we should be able to flush it per u-tube directions. After that we are on our own. Do we just fill the fresh tank with the mix and then run the hot water heater? How much mix do we put in the freshwater tank to fill the 6 gal tank etc? Thank you. Sandy KalleAnka 96 TK
Re: Demineralizing hotwater tank on 96 Tk Reply #1 – May 12, 2016, 11:48:51 am The pressure relief valve has threads on it. Get a coupling that will transition from pipe thread to hose bib. Most hardware stores will have them. then, buy some hose material, a few feet, a male and female hose bib connection for the hose, and a funnel. Connect the hose. Open the pressure relief valve. Open the drain plug to empty the tank. Replace the plug. Use the funnel to add the mixture. Close the pressure relief valve. Remove the attachments.In theory, it should work. When I did it, I removed the pressure relief valve, something I needed a pro for. I didn’t have the strength to get the valve to turn.Ken F in OR
Re: Demineralizing hotwater tank on 96 Tk Reply #2 – May 12, 2016, 06:17:55 pm SandyIn over twenty years of LD ownership, I have never demineralized a tank with vinegar, instead use a water heater flushing tool.Amazon.com: Camco 11691 Water Heater Tank Rinser: Automotive Water Heater Flushing Tool - Parts & Accessories - RV Water Heaters - RV AppliancesRemove the plastic plug on the water heater, the one used to drain the heater.Attach the flushing tool to a garden hose. Turn the valve, on the flushing tool, to the 'off' position.Insert the tool inside the drain hole and then turn the water on. Energetically, push the tool in and out, while rotating the tool. You are working to break up and flush the mineral build up that every water heater develops. With the plastic tube, there is no danger of damaging the heater, while physically scraping the scale loose.Don't be shy, work it. The tube will get scraped up but that isn't a problem. It's cheap tool.Every 30 seconds or so, pull the tube out and let the water drain out. In most cases, the ground will look as if it has just hailed, with thousands of small chunks of calcium littering the ground.Continue with this process until the water drains clean.This is a good thing for all LD owners to do annually, more often if you full time or use it in an area with hard water. The washed out mineral is very soft and can be swept or vacuumed up.When done replace the plastic plug. The plugs are easy to cross thread, so it is suggested to have a spare on hand. Do not use any metal plugs, plastic only.Larry As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Demineralizing hotwater tank on 96 Tk Reply #3 – May 13, 2016, 11:49:21 am Larry what is the problem with a metal drain plug? Mine had a metal drain plug when I bought it. Actually it's like a plug inside a plug but I had to remove the larger one to get the tool in to flush the water heater.
Re: Demineralizing hotwater tank on 96 Tk Reply #4 – May 16, 2016, 05:44:53 pm Quote from: Jay Carlson - May 13, 2016, 11:49:21 am what is the problem with a metal drain plug? Mine had a metal drain plug when I bought it. Actually it's like a plug inside a plug but I had to remove the larger one to get the tool in to flush the water heater. Plastic because it will not react with the aluminum tank and corrode the fitting in place. Also, if cross threaded, the plastic plug will deform, not the than's threaded bung. Plastic plugs are cheap, carry a spare.Avoid mixing dissimilar metals in any plumbing situation.Larry
